Use this procedure to display the MAC addresses that are learned or statically configured for a VLAN. In order to learn you have to be connected to another switch or host and receive some traffic.
View VLAN forwarding database information:
Switch:1>show vlan mac-address-entry
Vlan Fdb
VLAN MAC SMLT
ID STATUS ADDRESS INTERFACE REMOTE TUNNEL
1 learned f8:15:47:e1:80:0c Port-1/2 false -
2 learned 32:20:d3:81:00:77 Port-1/9 false -
4 learned b4:a9:5a:2b:78:31 Port-2/1 false -
3 out of 3 entries in all fdb(s) displayed.
View where entries are learned. The TUNNEL column indicates where in the SPBM network an entry is learned.
Switch:1>show vlan mac-address-entry spbm-tunnel-as-mac
Vlan Fdb
VLAN MAC SMLT
Use the data in the following table to use optional parameters with the show vlan mac-address-entry command.
Variable |
Value |
<1-4059> |
mac <0x00:0x00:0x00:0x00:0x00:0x00> |
Specifies the MAC address. |
port {slot/port[-slot/port][,...]} |
Specifies the port or port list. |
spbm-tunnel-as-mac |
Displays where entries are learned. The TUNNEL column indicates where in the SPBM network an entry is learned. |
